Message |
Hey, guys. While doing my fuel injector replacement I have discovered what was plaguing my car with radiator smell while driving, a leaky cylinder head plug in the rear side. I can see the radiator fluid that dried out around the plug (the lower one-the upper one is oil I believe) I got the L bar from Sears (17mm) but I have hard time turning it to unscrew. Anyone have done this before? be it that it is in a such a tight space (on the passenger side) not sure if 17mm L bar is big enough. Also, was wondering if anyone has used radiator/block sealant (especially the copper version) to solve this kind of problem. Thanks for your input.
